Dan_East
May 22, 2022Explorer
Fisherman wrote:
Q. Does the pin go all the way to the other side and is visible? You may be able to tap it out with a brass punch if you can figure out a way to support the end piece, or, some tool like a ball joint remover or big wide opening "C" clamp pushing in a smaller item to push the pin out the other side. Good luck.
It doesn't. I drilled it out, but I had a terrible time with it today. It took me hours to get that drilled out after breaking and dulling drill bits. In hindsight I wouldn't have bothered. If a person totally removed the end cap (drilled out the rivets) to where they could place the part in a drill press then it may be reasonable.
I'm not sure why they didn't place a long bolt through it in the first place (which is what I have now - I drilled it out all the way through). I used a 5mm bolt 50 or 60 mm long.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
