hbarker
May 06, 2019Explorer
prichardson wrote:
To determine if an A/C unit is operating to capacity one needs know the temperature of the air entering and leaving the unit. You say the output of one unit is 58 degrees. If that is the case and the temperature of the return air is 75 degrees or above, the A/C is doing all it can and the only solution is a higher capacity unit.
Yeah, Turn on both units on a hot day and LR air output is 58 to 60 deg. BR output is 48 deg. this is shortly after compressor kicks in .
LR unit NEVER blows any cooler., This is Strait Out Of unit. Not the ducts.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
