osbornk
Jun 18, 2007Explorer
Lee In Calif wrote:Skeet25 wrote:
Lee, This is what edge540 said about the same problem.
Had my kit installed two days ago. Now doesn,t work. Yes it worked fine on gas or 115 vac. prior to retrofit. I removed fount cover of the kit 5x8 sheetmetal now it works. Guess it restricts draft up the flew. If you haven,t checked yours on gas, may be you should.
Thanks Skeet25..... I WAS trying mine on GAS... I removed the sheetmetal and it seemed to help.... Now I have to try it on Electric..... Hmmmmm I wonder if others are having the same problem?
Does Dometic need to re-think what they are doing? Some times BANDAIDS leak........ In other words they DON"T work........
Maybe it's the installation. I had mine done and it works exactly the same as it did before.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 09, 2025
