1slomofo
Jun 17, 2020Explorer
theoldwizard1 wrote:wa8yxm wrote:
Springs do wear out but I see no breaks in them.
There are shops that can tell you for sure. I'm one one of them.
If there are no cracks in the any old the leaves, I would not condemn the hole pack. Take it to a pro, they can re-curve them and add a leaf. MUCH CHEAPER !
If you have flattened out those leaves, you might be overloading the tires !
Yes I will look into adding a leaf.
For the tires I am running XPS ribs - they are rock solid tires in my opinion and work great!
Had three of the four original factory tires blow in the first 400 miles of owning the trailer.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
