shastagary
Oct 07, 2022Explorer
you could use a terminal strip next to the solar controller to connect thicker cables from the battery and then a shorter pieces of thinner wire from the terminal strip to the controller that fit its terminals.
doing so will keep the voltage drop to the batteries to a minimum it depends on how far your batteries are from the solar controller.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
