Bend
Feb 26, 2021Explorer
Thanks for the discussion! And, considering:
https://www.solacity.com/how-to-keep-lifepo4-lithium-ion-batteries-happy/
and the above comments, here is what I got out of it...:
Should not charge/discharge LPF's below 32Fand should not consider charge/discharge above 113F.
So now BB has self-heating LPF’s that will over-count charging AH/WH on a shunted battery monitor. Do you think BB will also add a chiller to the BMS to keep the batts less than ~110F and do the same for a shunted battery monitor? 1 or both will add another parasitic drain.
And thus, its back to using a VM to guesstimate SOC.
I’m going to start calling LPF’s the “fair weather batts” because using them during many summer and winter situations without heating and cooling will make them limited if not just useless.
This makes the all(most)-weather capability with a weight penalty and lower cycle-life of FLA, AGM & SiO2 batts most attractive.
And, you might outlive a set. YMMV.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
