hilke40
Oct 01, 2019Explorer
It could still be the thermistor, even if ohms are okay as mine' 4 door was intermittent. Mine would always cool down when first turned on but would warm up sometimes a day later, or several days later, so the ohms were probably right. part of the time. It would be 0 in freezer and fridge would run 47 to 52. On mine the cooling unit test is to plug a working thermistor and leave the thermistor out in the compartment outside. It showed overnight 20 in top and 25 in bottom and froze a cup of water solid. On some models of dometic, unhooking the thermistor will make it cool constantly. There is a repairman from Washington on you tube that has a great video on how to install the upper fans, and baffles to direct air, as he says one manufacture doesn't have air directed correctly and the will never cool properly. My dealer thought I needed new control board, but the thermistor is what fixed it.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
