Glenn_And_Kitty
Apr 08, 2021Explorer
Original poster :
Since both cracks are accessible I'm up to trying again to do a repair. Since JB Weld covered with Eterna bond tape didn't work could anyone give me any suggestion as to what other material I might try.
Has anyone ever use the "as seen on TV" Flex Seal or Flex Tape on an RV tank?
I also saw a video using the heat head and plastic rods melting the plastic in a crack. I'm working under the RV on the bottom of the tank. Would I be able to use that melting method if I'm working upside down? I'm almost 70 years old and I can crawl under to work on the project but I'm really not up to removing the tank.
Glenn
Glenn
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
