DryCamper11
Feb 04, 2017Explorer
MrWizard wrote:
slide works , IF it is baffled correctly has fans, and NO dead air space above the fridge to trap hot air
some RV mfg, get it ride, and a it seems a lot more get it wrong
I've read the manufacturer's installation instructions a few times, and we need to check if the installation will be correct. I believe it will, but "trust, then verify." We've always had a roof mounted fridge vent and have been very happy with a propane fridge, but it's never needed any kind of fan to work well. The propane models available now all seem to need a fan, which surprises me a bit.
Is it general consensus now that the spate of fires has been mostly solved with the current fridge designs?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
