woodland_park
Jun 28, 2016Explorer
OK, we found the issue with the Generac LP generator not staying running!
There is a terminal block screwed into the frame about 8 inches below the voltage regulator. There are 4 blue 12VDC wires all labeled wire 14. 1 goes to the prime switch, 1 to J2 on the control PCB, 1 goes to the oil pressure and high temperature and the 4th I believe to a fuel pump that the LP version doesn't have. Anyway, the screw securing the male ends of the terminal block was gone and 2 of the wires had broken off the female spade terminal connector. I just stripped all 4 ends of the wires and wire nutted them together. Fired right up! Still need to order and replace the oil pressure switch, but the high temperature switch is at least in the game. So no switches or circuit board. Just connection, connection, connections.
Thanks for all the input!!!
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
