Re: Gray water drainage design help (see drawing)
evy wrote:
When I can dump the gray water on the ground I simply remove the plug from the drain inside the pump's temporary tank, the water is drained so the pump never comes on.
You better buckle up.. it may get rough in here.
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
