JustLabs
Mar 20, 2017Explorer
Old-Biscuit wrote:
Follow battery positive cable that goes to converter.
Close to battery will be a In-line fuse OR DC Circuit Breaker ---most likely 30A or larger
It has tripped......therefore no DC from battery when not connected to shore power
When on shore power converter is supplying DC...but no charging of battery
You're correct,there is a 30 amp fuse inline near the batteries. It tested good this morning. Replaced it and the second fuse also tested good. Still no 12V power.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
