Re: Honda 2000 running errantly - Altitude issue?
it probably part of the problem
also what about fuel blend, winter versus summer
what blend is in the Honda
how does it run, with econ mode off ?
me i would probably run it with the partial choke and then check the sparkplug to make sure it was not getting fouled
and while you cannot adjust the MIX screw
is there a throttle stop screw, where you can raise the idle speed a little bit and perhaps smooth out this "hunting" problem
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
