GaryS1953's avatar
May 12, 2017
Re-igniter - where does yellow wire go?
Hello All - in trying to diagnose / fix Dometic RM2652 propane operation issues I accidentally pulled the yellow wire off the re-igniter. There were only 3 wires total, and the only one disconnected was the yellow. Does anyone know if it goes on the positive, or negative terminal? Thanks
  • Wow, thanks Guys. I guess I just don't speak "wiring diagram", but it makes sense to go to the positive terminal.
  • Should go to + other end should be gas valve and main circuit board. Nothing is connected to the L terminal.
  • wnjj's avatar
    wnjj
    Explorer II
    Joe417 wrote:
    On page 14, upper right corner, it shows the yellow wire on the "+" terminal. It applies power to the re-igniter board when the gas solenoid is energized.
    I agree. I also found pictures of modules like that with the yellow wire in the 3rd position (+).
  • On page 14, upper right corner, it shows the yellow wire on the "+" terminal. It applies power to the re-igniter board when the gas solenoid is energized.
  • Hmm, I can't make sense of it, but you are saying it's correct I my picture?
