neonjohn
Jul 02, 2017Explorer
time2roll wrote:
Not sure I would install a big 2000 watt inverter if I had an on-board generator.
Maybe something like 300 watts is way easier to run or charge small items. For microwave, hairdryer, A/C just use the generator. Or do you need electric coffee before generator hours?
I don't like to run the generator unless it will be on long enough to fully heat up. That way moisture from combustion won't remain in the crankcase and muffler.
The large inverter is primarily to run the minisplit generator. That it can run other heavy loads is just a convenience.
John
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
