LittleBill wrote:
you can also catch the unit on fire and burn yourself alive. maybe try a smaller project first before you go to the big boys
wasn't the plug on the inverter hard wired? isn't it a nema 15 end?
inverted or not, the unit is rated 750w regardless if its inverting or passing through power.
i am assuming you cut the cord in half and used the one end to wire it back into the panel.
the significant wire size difference should have been slightly obvious the unit was not designed for this
Actually you are incorrect. AC pass through is 1500W
"When connected to an AC power source, the APS750 can provide up to 1500 watts continuous power."
Thanks for chiming in but I'll be taking the advice other big boys who have been nothing but helpful.
Good Day
