strudeau
Oct 20, 2021Explorer
rdhetrick wrote:
Most likely the hot relay in the transfer switch. I just had to replace mine, very similar situation - when plugging into shore power, I had power for 30 seconds, then lost it.
In my transfer switch, there is a 30 second delay in the neutral relay to give the generator to come up to speed before transferring the full load. The hot relay was shorted so when applying shore power, it triggered the 30 sec delay. During this delay, everything worked, but as soon as the neutral relay switched, shore power was lost.
Replaced the relay and all is good now.
Not sure if this is it or not as the power travels from shore connect, to transfer switch, to main panel, to Charger/inverter. If I have a transfer switch issue, why do I still get power to my non-inverter circuits such as washer/dryer and AIr Conditioners?
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 12, 2026
