Toogreys
Nov 27, 2014Explorer
YC 1 wrote:
After downloading the users manual it is fairly useless. There is a fuse panel under the dash and one that says it is on a "bulkhead". It would have a couple of large solenoids and a fuse block. Use a 12 volt test light versus just looking at the fuses. Reach behind the dash if possible and jiggle the connection on the ignition switch. If I had a road map (schematic), I could be a bit more useful.
YC 1 - Ain't that the truth I have the owners manual and absolutely no help. I located the fuse box under the dash and ther is no cover so no map on what each fuse is for! There is a panel on the bulkhead in the bedroom but I think that one is more for the house .and is more like a house circuit panel with the switches.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
