SaraL2282
Jun 28, 2019Explorer
BFL13 wrote:
which has the adjustable voltage feature you might find useful
What are the chances I will actually use this?
BFL13 wrote:
One way is to use the black and white wires to the 6300 input (the black goes to the 120v circuit breaker marked "converter") and use them on a standard household 15a receptacle.
Any reason I can't just cut off the plug and wire directly together in a J-box?
BFL13 wrote:
Jumpering the fuse panel is easy. The 6300 board has two positives (red and blue) instead of just the one blue. So you add a wire over to join their two lugs, so now the blue (to new converter pos) will do both "sides".
There is info on jumpering I will link here on edit, if I can find it
Thank you! Sounds plenty easy.
Forgot to mention this is a 30amp rv. The current converter is 45amp. Should I upgrade that? How much? We don't run much: a/c, sometimes microwave or coffee pot or hairdryer. Wiring in rv is 14/2 I think. It's white romex but seems heavier than modern, so it may be 12/2. I see he PM3-60LK is actually about the price as the original 45 I posted. Much less than the PM3-5LK.
You are awesome!
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
