Munk888
Jan 12, 2020Explorer
Thank you very much for your reply! Good to know that the slightly less amperage set of batteries is not a culprit. Wiring. I duplicated the original exactly to the original as far as I can tell. In the pictures I shared there on Imgur, on the right battery, the negative terminal has a small white and small black wire co-mingling with the big power cable. Do those need to stack in a specific way? I'm also fairly certain that at no time I did a neg/pos tap tap. But, who knows? Maybe I did booger something up unknowingly...thanks again!
Having RV issues? Connect with others who have been in your shoes.24,240 PostsLatest Activity: Apr 26, 2025
