tsweez
Jun 04, 2013Explorer
Both are great suggestions.
I'll revisit the bracing issue but I do have a brace on the bottom of that part of the compartment. Albeit not much of one. I was also considering somewhat of a backwards approach as well. I currently have 3/4 inch ply which is secured to the floor. I thought of anchoring some stranded aircraft cable to the battery platform to the subfloor above. That might take some of the pressure off in the event of a catastrophic failure.
As for the sponge idea... I'm on it!
Cheers,
Tim
Cheers,
Tim
pianotuna wrote:
Hi tsweez,
Nice job.
You may need to add (weld?) a bracket under the entire storage cabinet. The compartment was not designed for that amount of weight. It would not be nice to have the batteries detach from the RV while trundling down the road.
I "hid" my air vent on the rear side of the compartment and used a sponge to keep dust and dirt out. That let me put the vent up a bit higher than if I had gone through the door. I'd suggest covering the "back side" of your vent with some thin sponge to keep out dirt as well.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
