brisath
Apr 06, 2018Explorer
wa8yxm wrote:
It will not say RELAY on it but Flasher. How to ID. If you activate the turn signal or flasher and it's working you can hear it (it is what makes the click, click) and possibly feel it if you touch likely
As two of us have said Fuses are in two places. one is the main chassis fuse box (under hood) the other is the COnvience block to the left of the driver's foot.
NOTE: Some of the fuses on that block. >Well the body builder hooked mine up weird so some of the fuses are not what they should be,, IE: Air Conditioner (HEVAC) is AXU-1 instead of "Heater" as it should be.
Thanks. We are getting clicking sounds with turn signal, nothing with flasher. If we find what is clicking will that be the flasher relay too? And if it is clicking for turn signal does that mean the relay is not the problem?
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 09, 2025
