Caribou
Jan 12, 2015Explorer
I read a lot more over the weekend. Had to do the glow plugs on my diesel, so I didn't spend much time on the generator. I borrowed good compression gauge from a friend because mine is pretty old and beat up. The compression test with his gauge read 150 lbs, so I know the engine is good. I wish I could find a rebuild kit for this demand regulator.
The test with the manometer between the demand regulator and the carburetor should measure a slightly negative pressure. This is due to the vacuum of the piston pulling the fuel in the the cylinder. I still haven't done that yet.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
