Robert6401
Mar 01, 2017Explorer
wa8yxm wrote:
Using both Gas and Electric, at the same time, if possible (not always) improves recovery time
Atwood makes a 10 gallon water heater that fits in a six gallon hat. What it does is over heat the water than mix cold in via an automatic mixing valve so you get 2/3 more hot water... NOTE: the mixing valve is an additional point of failure, but I've not heard bad things about them.
I'm not sure if this is what you were referring to with the Atwood, but it sounds pretty intriguing. Anyone with personal experience with one of these Atwood XT Water Heaters?
More info and diagram of system
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
