Bend
May 25, 2015Explorer
PD9245C-14.8
I was trolling Best Converter and ran across a 9200C series doing bulk at 14.8v. Seems only in 45A for now. http://www.bestconverter.com/PD-9245C-148-45-Amp-RV-ConverterCharger_p_610.html#.VWPmaI9...
KJINTF wrote:
It's a simple modification to increase boost voltage from 14.4 to 14.8 or almost anything you desire. Pin #5 of the micro controller is connected to a 32.4KOhm resister - drop the value by several hundred Ohms and the Boost increases - Simply solder a 60KOhm across the resister in question.
