Vintage465
Oct 24, 2023Nomad
I think you need to get the spec's on the panel output to size the controller correctly. In my case, my panels provide just a bit more than 8 amps(best case), time three panels equals around 24v +/- a bit so I have a thirty amp controller. I think Victron is the top of the line and if you can afford it that's the way to go. Also, if you plan to increase, get a controller to match the possibilities.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 16, 2026
