jodeb720
Oct 26, 2023Explorer
this is all excellent advice -
One question though. Can I manually switch the controller from bank 1 to bank 2?
As I stated, I run my batteries through a marine switch - which feeds from bank 1 or bank 2 or both. I have them separated because of the age difference of the batteries and use. Bank 1 serves the RV House needs (water pump, fans, lights) and Bank 2 serves my Inverter. I currently have two separate chargers which I run off my generator to bounce them back to 80% or more.
If I have my solar setup, will I be able to focus all the amps on Bank1 until it reaches 80% and then switch it to bank 2?
If so, I can use a mechanical switch (as I have for the source of power in the trailer), but what impact will a mechanical switch have for designating the destination of the charging on the controller?
Will a sudden disconnect and reconnect from bank to bank cause a failure?
Do I need to disconnect the feed from the Panels first to the controller, then switch over, then reconnect the feed from the panels?
i know this would be a lot easier if I just had one battery bank of 420 amps. Hence, I'm asking the questions before I let the blue magic smoke out of charge controller prematurely! :)
Thanks so much!!
Thanks so much!!
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
