RV-1_2n-FUN
Jan 08, 2020Explorer
Thanks all.
Yup, the T's are in series as we all know so the 12's have to be parallel and just figure that in the 10 years we have had the MH we have never Dry Camped and due to my prostate cancer are using it even less.
opnspaces wrote:RV-1/2n-FUN wrote:
Need to replace 2yo T-105s due to my neglect and wondering if 2-12V 24DC in parallel are a wiser less expensive choice since not using MH dry-
camping?
https://www.walmart.com/ip/EverStart-Lead-Acid-Marine-RV-Battery-Group-24DC/180350522
TIA for expert opinions as always
If as you say you are not using the MH for dry camping. And if we can assume you are always going to be plugged in to shore power. Then buy the cheapest battery you can.
The two 12 volt batteries will work fine for you. Your current T-105's are wired in series to give you 12 volts. If you replace with 12 volt batteries then make sure they are wired in parallel so you still only have 12 volts.
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
