ExRocketScienti
Apr 26, 2012Explorer
JBarca wrote:FastEagle wrote:JBarca wrote:
If coming out of this I end up needing new wheels and tires my options are not many. So far I have the ST E range that Capri Racer suggested and that is about it. I have not found any LT tire that fits the diameter and at least a 2,500# max load rating. If some one knows of a 28.3" OD tire with that load rating in a LT please point it out.
John
Take a look at the very last item in this reference. Can you make a 29.3" tire work?
Maxxis LT
FastEagle
29.3" OD creates wheel well issues. I need to change the hangers to make them work.
However they list a (4th up from the bottom)
TL22212000 - 205/75R16C - 113R 10 BSW - 28.1"OD - 8.20" wide - 75psi 2,535# 5.5"rim.
I just do not know if that tire is acceptable in a trailer situation or if I need extra reserve capacity. I do not understand what type it is. LT is not listed there. And I cannot find a rim that narrow in 16". Yet anyway.
There is also a
TL22214000 -215/75R16C - 113R 8 -BSW 28.7"OD - 8.80" wide 70psi 2,535# /6.00" rim
And I can buy a trailer rim for that one. I have to deal with 0.2" of wheel well clearance though.
John I think those are P tires. You would have to divide the load capacity by 1.1. So the one that is 2535 at 75 psi would give you only 2305 pounds.
Having RV issues? Connect with others who have been in your shoes.24,228 PostsLatest Activity: Apr 04, 2025
