StirCrazy
Dec 06, 2024Moderator
Re: SF42 Furnace Running - will Heat for a few minutes then cold
so let me try get this clear, the thermostat calls for heat, the furnace does its purge cycle then lights, runs for a bit and goes cold.
1, is it actualy lighting? are you getting hot air then it shuts off? or is it trying to light then failing?
I had the issue where it would light, sometimes, but when it shutoff and went to relight the next time the thermostat called for heat it wouldn't light.. then eventualy it wouldn't light at all. this ended up being bugs in the exhaust path and even inside the main burner. once I took it all apart and cleaned it it worked perfect untill I lost a board. with this it wouln't light at all. would go through the purge cycle but just wouldnt light.
