flash_flood
Aug 28, 2013Explorer
I did not wear gloves when I attached the fill connector but I will get a good set to keep in the coach in the future. I didn't expect to attach it myself but he said he couldn't get it started and I felt bad.
I'll run soap and water over the tank tomorrow to see if it is in fact from the little plastic bleader. Hopefully I can get it to stop with a channel lock until we can exhaust the propane and then I'll replace it. I really don't want to cancel our trip. I was able to inspect the gauge on the tank and it is at 80%. The next marker would be 85% and the label on the tank states do not fill beyond 80% so I think he got that right. It must be that little plastic bleeder as you guys think.
I'll report back tomorrow when I find the leak. I appreciate the quick responses from you all. I'll sleep a little better tonight. It's a 96 Class C Tioga and the tank is outside so it probably won't accumulate anywhere.
Thanks.
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 26, 2025
