byates
Aug 30, 2011Explorer
-=dwh=- wrote:byates wrote:hedge wrote:
Help...
I just purchased one of these tonite. I put gas and oil (400ml) in it and it fired up after a couple of pulls but then went straight into overload mode (didn't have anything plugged in). I shut if off right away. Now when I attempt to start it the cord has a lot more resistance than it did before and it doesn't start.
I got it at costco so it's likely going back unless someone knows a quick solution.
PS: is 400ml the correct amount of oil? it says 0.4L throughout the manual but when I put 400ml in it seemed like it wanted to come out the fill port. I measured exactly 400ml and turned it over to make sure there was no oil in it to begin with.
Given all the reported problems with the 2000i, I would return it to Costco. While I don't have any firsthand experience with the Generac line of generators, Costco online has the Generac 2000/2200 inverter for $529.00, shipping included. The Generac has a 126cc engine vs the 80cc on the Champion and should be more apt to deliver on its advertised performance.
Just FYI:
When my 3rd Honeywell failed, Generac had just taken over Northshore Power (and the Honeywell branding contract). They were going to send me a Generac as a replacment, so I looked into it. The Generac is made by (IIRC) Suzhou Tiger Power Machine Co. in China. I believe the generator currently being sold under the Honeywell name is the same generator.
It might be a great generator. I wouldn't know. It turned out that it's a 49 state gen and they couldn't send me a replacement because I'm in California. So they sent me a refund instead.
(Which I used to purchase an 80cc 1200wC/1500wS Champion 42431. Aside from being noisy and needing an ounce of oil added with every tankful of fuel, it's been humming along without an issue for over 300 hours now.)
Good information, thanks. Now that you mentioned it, maybe that brand takeover by Generac was the reason reports of Honeywell unreliability decreased.
I don't know much about the Generac brand either and wasn't promoting it, just giving the original poster a similarly priced alternative from Costco to look into.
In addition to Honda and Yamaha, the Onan Cummings inverter line is the only one that I could recommend without hesitation. But of course, they are more expensive.
Is your Champion 42431 also a rebranded product? I believe that several different Chinese manufacturing companies ship generators and generator parts under the Champion brand.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
