Glenlivet
Apr 07, 2013Explorer
MrRchitty wrote:
You can give a quick blast of starting fluid with the air cleaner cover removed and see if it will fire up.
Good luck.
Starting fluid is not a good idea! It will wash all the lube off the cylinder walls faster than any solvent. It's only meant for diesel engines that have so little compression they can't make enough heat to fire on a cold day. Even then it's hard on a big diesel. In a little gas engine...
If a gas engine has all the things a gas engine needs in order to run, it'll start. A little prime with gas, sure. Starting fluid, no. Please don't.
For an experiment take an oily piece of metal and hit it with the starting fluid. It'll be squeaky clean in no time at all, right to the metal pores.
I use a can of the stuff to remove oils from machining processes and even fingerprints. Works better than anything else, even spray brake cleaner is no match for it.
Sorry to be all insistent about this topic but that stuff is nasty on a motor.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
