dman535
Sep 29, 2020Explorer
The trailer has two 3500lb axles with 10" drum brakes on each wheel. Yes the wires run through the axle tubes. Here is what I have done as far as diagnosis so far.
1. Had son max out the controller manually to 11 on the meter. I shook, moved touched all the wires and no shorts were shown. The problem only shows up when the trailer is in motion.
2. I pulled all the drums off, checked wires and once again had son put power to the system while I moved the brake arm. No short found. Wires looked ok.
The trailer only has maybe 1500-2000 miles on it - so I thought about the inside the axle tube chafing issue - but my dealer warned me about the warranty issues if I started cutting wires.
I don't think the issue is with the car or the controller, hooked the trailer up to another truck and it did the same thing. It felt different almost like a chug-chug-chug as the brakes were being applied. The biggest issue I have is that the short only shows when the trailer is moving. Only way I can think to narrow it down is to start cutting or disconnecting wires and narrow down where the issue lies.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 29, 2026
