bartlettj
Jul 23, 2019Explorer
It is very likely that they do need adjustment. They significantly loose mechanical advantage between the actuation magnet and the shoes when they have too much clearance. They adjust exactly like you say. I recommend replacing the bearing seals while you are in there. It's pretty easy work but quite messy.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
