purplekeenah
Sep 22, 2021Explorer
Thanks to all for the info and suggestions. The new facility I'm going to use is a 7 day/16 hour per day unlimited access, climate controlled, security coded warehouse. After weighing all or your responses, I've decided to plug the rig into their 110V outlet, same as I do at home between trips, then check the monitor after a couple of weeks to get readings. At the same time I will check water levels in the batteries.
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 19, 2025
