Gdetrailer
Sep 02, 2018Explorer III
Johno02 wrote:
Star washer is to help keep the connection tight, not to provide better connection, although it probably does. Primary is to make sure you have a good connection, then star washers help keep it tight.
X2
The star washer is nothing more than a "lock washer".
I would be a bit concerned about placing the star washer in between the ground and the wire terminations, especially if it is OUTDOORS like a trailer frame. The star fingers will allow moisture to find its way between the termination and the frame and in high salt areas like ocean side or in the rust belt in winter will eventually result in a corroded connection.
If you must use a star washer, then put your termination dirctly against the steel frame, then add a PLAIN washer, then your star washer and nut.
On outside connections, paint the termination after you have torqued it to prevent corrosion.
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 07, 2026
