Wild_Bill_888
Oct 21, 2019Explorer
The answer depends on the detailed design of the voltage regulator circuit. A high quality design will prevent big spikes.
To test yours, plug in a filament type bulb with various loads you normally have and watch for over bright flashes when it runs out of gas.
A compact lightweight generator running at a high power setting has a lot of excess heat stored inside the case. Running out of gas or shutting off with no cool down subjects non power components (rubber, plastics, capacitors etc.) to a temperature spike, aging the equipment.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
