DougMatthews
Mar 30, 2017Explorer
dougrainer wrote:
IF you are testing while the burner is ON. WHY????????? If the burner is ON, the Tstat has not reached its shut off temp. LET IT RUN UNTIL IT SHUTS OFF. Then test your water. Doug
The unit used to reach temp and shut off in under 10 min (anecdotal, never measured).
Seems that if it is barely warm in 30 minutes it's going to be hours (if ever) before the Tstat shuts it off. That won't support taking a shower.
/Doug
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 10, 2025
