LangsRV2
May 02, 2015Explorer
RJsfishin wrote:
Quote:
Actually believable because the tech spent close to an hour with us upon pick up to show us how everything worked.
Everything ?? Care to rephrase that ???
Or weren't you paying attention.
I'd think it would be perdy simple.
Neither of our other 5th wheels had a valve to switch between the two types of water. Just a button on the pannel to turn on the pump. We actually spent a fair amount of time in the water pump area with the tech. Partially because we were interested in the water filtration system and because the water pump is located in the basement where it is much easier to access than our other two 5th wheels where it was located in a tiny compartment under the sink. There was no mention of a valve to switch between the two water types.
I would think this would be simple too!!!
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
