LangsRV2
May 04, 2015Explorer
4x4van wrote:
Still curious as to the brass valve that the OP mentioned; a low point drain valve, perhaps?
Once the RV was home and I got a look at it, I identified it as a fitting to use for winterizing. It was capped off with a brass fitting. The hose you would use to stick in the gallon jug of antifreeze isn't there so we will have to get one of those. Happy that the winterizing fitting is there and easy to get to. In our old RV's it was impossible to even fit the fitting near the pump so we had to pump though the city water connection.
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 20, 2025
