...Is the water heater drain plug? Are they all the same? There are all manner of packs of these floating around. Like THIS ONE. Are those angled wrenches of any use? I'm thinking mine is...
The wrench that comes with those plugs has two different sizes. I would think that implies there are two different size plugs out there. At least on the outside. The inside diameter of the drain may be the same on all water heaters. I increased the bend angle on that tool and it worked just fine. Channel Lock pliers have worked also.
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
