PawPaw_n_Gram wrote:
I've seen voltage below 100V at rally sites, COE, National Park Service and commercial campgrounds from low end to high end.
based on advice in this forum I made an adapter that had a 50 amp plug and two 30 amp outlets so that I could sample the juice and hook to the better side. all too often when old campgrounds update their systems it seems like many/most of the 30 amp outlets are on the one/old side with the new side having less of a draw. If you are plugged into the bad half in the middle of the day when all of the ACs are running, water heaters on, fry pans on etc., microwaves. the juice can take a tumble causing an undervoltage situations.
bumpy
