wa8yxm
Nov 08, 2020Explorer III
Two suggestions
ONE Driver side. farther from antenna grabbing tree limbs as you drive down a narrow road.
Two Push up pole mount for the antenna Need not be expensive just two pieces of pipe oh say about 10' that "nest" on inside the other. Antenna mounts to top pipe You put a "EYW" type bolt just below the top end of the bottom pipe. and either use the larger pipe to push up or "Slot" the lower pipe and add a threaded hole in the inner pipe with a knob (Like an awning lock knob to push up with.. DOWN for driving UP when parked.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
