Raife
Nov 08, 2020Explorer
Thank you for the suggestions. Wrt to the driver's side mounting, my thought had been having the router on the passenger side would provide greater broadcast of the Wi-Fi into the camp site when we are stopped by being closer and removing interference (i.e. traveling through the materials of the trailer). My antenna cord is only 6' long so I can't mount the antenna on the driver side and run it across the roof or snake it inside the ceiling to reach a passenger side mounted router. I'll look at it again to see if the router distance would make a huge difference (router on driver or passenger side)
I'm assuming you meant 10" (inches) and not 10' (feet) on the pole idea. I'll look into that, but was trying for simplicity and set and forget (to the extent that is feasible).
Edit: So I did a bit of looking into the logistics of your pipe suggestion and am struggling. I envision PVC pipe as the option.
- Would you use a female threaded PVC pipe to accept the antenna? Given the install hole size is 1-11/16, I would assume the thread pipe size is 1-3/4, but I am not finding any 1-3/4 female threaded PVC.
- I would think a flange secured to the roof would be the other end of the unit...does a flange provide enough surface area (i.e. hold area) to account for the wind resistance and leverage of the height? Would I need to use screws to secure it? Or just the sealant?
- How do you envision accounting for the cable movement during the required up and down? I had initially thought all the wires would be inside whatever construct I use. However, this would mean in the tube in tube setup that the wires would need enough space in the tube the be folded or doubled back to accommodate the up and down...or the slack would need to be in the inside closet. I had envisioned "filling/insulating" the hole through the roof, but if I needed to leave the slack in the closet, I'm not sure I could fill it...
- I am not familiar with an "EYW" type bolt and also not sure how having a screw arrangement wouldn't deteriorate over time. Also not sure PVC is strong enough to handle it over time.
If you have any more info or pictures it would really be appreciated.
Thank you.
Thank you.
Thank you.
Thank you.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
