Well I started to dig into the electrical side of the coach. Noticed the Xantrex was telling me that batteries where charged BUT a switch on the electrical panel showed my house batteries down to 11 volts!
inspected the 4 interstate deep cycle (golf crart) batteries & found ONE terminal hotter than a fukashima reactor core!
Went down to Tractor supply & picked up two 2 gauge cables, pulled ALL connectors, cleaned, replaced two cables & used the dielectric grease when I re-assembled them!
The batteries where pulled down to 8VDC!!
Well, This AM I checked the converter & found ALL batteries back to a full charge. I'll load test to determine the state of the house batteries.
AMAZING!!! Crappy cables can take out a good set of batteries!
Still planning to place a couple hi voltage panels so stay tunned. Will start ordering the hardware needed to make up cables..... Stay tunned.
