naturist's avatar
naturist
Nomad II
Sep 23, 2021
Real life solar results
Just thought I’d post what I’m seeing. I have 400 watts of panels feeding 250 Ah (3000 watt-hours) AGM batteries. I ran them down fairly deeply, pulling 100 Ah of the 125 Ah feasible. Yesterday was rainy and fairly heavily overcast. So a little after noon I was getting around 25 watts from those panels. Today in bright sunshine I saw 378 watts.
I have established on several occasions that a good day will yield around 1600 watt-hours from those panels. For folks thinking about adding solar to their RV, I hope these numbers are helpful. The solar array, battery size, and intended power use must all be matched for best results. The usual battery trailer manufacturers put on units is the cheapest 80 Ah battery possible. If you find that battery adequate for your camping needs, you can probably make do with a 100-150 watt solar panel, as long as it is sunny. Rainy days, however, not so much.
I invite other folks with real life experience to share their numbers below so that we may help folks make up their own minds about what they might need.
  • Our Escape came with a 170 watt panel on the roof and a GoPower PWM SCC. As long as we had decent sun it was fine, but shading would cause problems, plus the 170 watt is mounted on the back of the camper with about a 5 degree slope. Just don't camp with the panel facing north.
    We have 260 ah's of SiO2 batteries.
    We didn't want to worry about use, so I installed three 100 watt panels, and a Victron 100/30 SCC, so now have 465 watts in parallel on the roof (wired in parallel we lose 5 watts from the 170 watt panel, in series we lose 65 watts). We don't have a microwave (don't want or need one), and don't have an inverter (but want one for a toaster). We now have all the juice we need and an inverter for the toaster will be installed next!
    Enjoy,
    Perry
  • I have 680watts of solar panels and 400ah of battery. Seems to serve well for my class.
  • 4-5 times the nominal panel rating in watts is what is normally assumed...so 1600w-h per day out of 400w of panels makes sense.
    Overcast, small shadows, shorter winter days, etc...can really kill output.
Having RV issues? Connect with others who have been in your shoes.24,326 PostsLatest Activity: Oct 24, 2025
