ArmySFCRet's avatar
ArmySFCRet
Rear camera on Class A issues
Recently turned on the coach and noticed the video feed to the rear showed a picture then some "static". The picture went blank and now only shows several white parallel lines. Double lines when camera is connected. Single white line on Cam2 with no camera connected.
The Voyager monitor was replaced about 5 years ago due to a monitor failure. This does not appear to be the same issue. Unit is b/w.
Camera model is VBCS150.
Coach is identified in sig.
On edit:
Disconnected camera and reconnected. Moved cable to Cam2. Still no pic. Now appears to be another VOM 58 monitor failure.
1 Reply
  • My 2002 weldex monitor failed and when I replaced it I modified the metal bracket that held it in place, it blocked all the monitors vent holes. My guess was it caused overheating and then failure. Just a guess, we'll see if it helps in a few years.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
