MrWizard
Mar 08, 2017Moderator
The OP has a Class C , RV not a tt Not Towing, Not a Tow Voltage Problem
He has an alternator voltage regulation problem
PT
Can you put a jumper cable across the charge circuit, jumper your isolator/relay circuit so everything is common with the chassis battery and alternator
This should bring up the charge voltage and amps into the house batteries
Just need the positive cable to bridge the terminals
PT
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
