BFL13
Jan 02, 2015Explorer II
Some 1998 MHs have a PD 9100 converter. If your Class C does, then just get a Charge Wizard for it so you get decent amps while charging on Generator.
Otherwise you need a higher amp portable charger like the VEC1093DBD or a deck mount converter that will do more amps in the 14.4 volt range or better. You can leave the existing 13.6v converter in place either way. Your charging is taking so long now because it only goes to 13.6 instead of 14.4 or higher.
A second battery would be a good idea too.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
